zdw103 configuration issue
Have wired up canister lighting with a ZDW103 and a AS101W.
Everything works ok, except the light level only seems to be at about 80% when turned “ON”
I can tell this, because when turning the switch off from the AS101W, the lights briefly flicker to 100% for about 1 second, then begin to dim.
The wiring was done by a professional electrician, so I feel comfortable with that.
Any ideas?
What type of bulb?
You don’t want to run CFL’s with these type of switches.
standard incandescent . . . canister lights
BTT
