Very new and confused
Just added a Vision Garage Door Detector to vera plus in a attempt to automate my garage door.
First question is do i need to change any of the settings on the Door Detector as current its status does not appear to change on the dash board regardless of weather the door is open or closed?
Thanks for the reply’s.
I have added the device to favourites and it displays the same: please see attachment.
gerardosamara, How do you have yours liked up? Have you used the garage door plugin?
I have not used the garage door plugin to include it in the VeraLite .
I followed the normal inclusion proc?dure .
It shows the same device in Vera as your screenshot but i can arm/desarm it .
To test it , I kept it in my hand and simulated a door open / door close by moving the device .
Device #92 “ZG80101 Porte Garage” in “Garage” is no longer tripped.
Device #92 “ZG80101 Porte Garage” in “Garage” has been tripped
