Z-wave.me ZME_WallC-S under UI 7 (Edge) to trigger Scenes
I can use the ZME_WallC-S to control devices successfully (although very hard to get it to work) but not to control a scene.
The devices is paired as a Generic Z-Wave device, but in this way when I want to select it as a trigger for a scene, I only have the options for when it is turned on or off, not when a button is pressed.
Is there a way to manually let the Vera Edge know what kind of device it is so it can be used for scene triggers? Or is there another workaround to get this to work?
Hi Martijn,
I have a couple of these units and I can’t get any of them to work. I’ve got a VeraEdge (firmware1.7.1089)
I’m relatively new to this and can’t get my head around Luup coding. Could you possible send me some screen shots of your setup so I can try them out on mine?
Did you guys get this one to get it to work to start a scene?
I am getting a headache, because I am unable to start a scene.
Didn’t see this one as I made a new topic too:
http://forum.micasaverde.com/index.php/topic,32498.0.html
