I was also looking in to this and send danfoss an email and got the following reply.
[i]I am glad that you like the design of the product.
Our new electronic radiator thermostats comes many different versions (different adapters, instructions packages ect.)
Overall there are three different kinds
a) Living ECO – a standalone programmable thermostat
b) Living connect – A thermostat which can be controlled be the Danfoss link panel
c) Living connect Z – a thermostat that can be controlled by a z-wave controller
From what I read in your mail you are interested in the living connect Z (which communicates using z-wave and has code nr 014g0012)
This means that you can control it from a z-wave controller
I have attached a user guide to this email – in it you can see the technical requirements the controller need to have in order to properly control the living connect Z.
(I know that the Vera comes in many different versions so be sure to get a version that has support for SUC)
On top of the technical requirements you can of course evaluate the different user interfaces, but as this is a very subjective matter I will stop by saying you should look for a user interface that displays the connect as a Radiator thermostat.
I hope this answers your questions[/i]
I was looking in to this SUC and found that it is set to 0. Would that change any thing (i own a Vera lite)?
