Z-wave association issue
Hello,
I’m trying to associate an intermatic dimmer switch and a motion detector (HSM100) and i’m having some problems. I was definitely able to do this in the past, but it doesn’t seem to work now.
I am going to the dimmer, selecting “Custom Z-Wave Settings”. I create a group ID=1, I then press set and select the dimmer, and the motion detector under the combo device. I then save and let vera reload.
Unfortunately the light doesn’t go on with motion, and I’ve checked the custom z-wave commands for the HSM (things like light threshold etc).
The odd thing is that the dimmer shows as a red cog forever after I add the association. If I remove the association it goes green straight away.
Any ideas?
Maybe all the devices need to scene capable or asscociable with other devices
From the wiki:
To see if a device is scene capable and can work with a Leviton scene controller in Method #1, click the ‘+’ button next to the device, look at the “Capabilities” line and look for the number 44 after the | sign. If it’s there, the device is scene capable.
Not sure if this is the answer, just a thought
Capabilities show as : 209,140,0,4,17,1|38,39,114,115,133,134,
Another device (a plug in appliance module) which worked previously is : 201,4,0,3,16,0|32,37,39,114,134,
This worked previously but now shows the same error as the new module. So I think this is a bug introduced in the more recent versions.
Any other ideas??
Leviton notion of “scene capable” is something different and should not affect associating light switch to a motion sensor.
What device is it a HA06C, HA14C, or HA20C switch?
I’ve tried with a HA02C, which definately worked before but doesn’t work now.
And
HA20C which I just got
Now neither works…hmmm
Sounds like software :frowning:
Does MCV still read the forums? Or do I need to open another ticket?
Open a ticket
Opened…lets see if I hear anything!
