Z-wave and multi-pole lights
This may be a silly question, but if I have say 3 switches that control 1 set of lights, can I put in one multi-pole z-wave switch to control the light or do all 3 have to be z-wave?
I am debating which lights to make remotely controllable and the cost can add up quickly as I have a lot of 2 way and 3 way dimmers.
No, you use the slaves for the zwave switch your using.
If you search the forum for three way switches… You will find a ton of info on how to wire them.
It’s not exactly a drop in wire for wire replacement.
When you research this, you will see that in this case (3-way, 4-way, etc.) most manufacturers produce a Zwave enabled main unit to replace one of the existing switches and Auxiliary Devices that will replace all of the others. they enable 3-way like switching but actually work a little differently (and from the existing wires).
There are other devices that can function literally “behind the switch” that you can use the existing switches.
Reference http://www.amazon.com/Aeon-Labs-DSC26103-ZWUS-In-Wall-Controller/dp/B008VWBNAU/ref=sr_1_5?ie=UTF8&qid=1393946777&sr=8-5&keywords=aeon+switch
Be sure to open up this boxes and look for a Neutral wire in your switch boxes. Some switches require them, a few do not.
[quote=“Bulldoglowell, post:3, topic:179953”]When you research this, you will see that in this case (3-way, 4-way, etc.) most manufacturers produce a Zwave enabled main unit to replace one of the existing switches and Auxiliary Devices that will replace all of the others. they enable 3-way like switching but actually work a little differently (and from the existing wires).
Be sure to open up this boxes and look for a Neutral wire in your switch boxes. Some switches require them, a few do not.[/quote]
At about $45, the in-wall dimmer version of what you listed is interesting. Then I don’t have to replace any switches. Other than having to try and fit that in the box, are there any other downsides? It seems like it is $45 (assuming you already have regular dimmers) vs around $150 to control 1 light from 3 switches.
I believe you won’t be able to Dim with the existing switches just on-off, so add the cost of a scene controller to adjust the dim, unless you plan to use a mobile/tablet exclusively.
I have yet to use that particular device, but I am sure there is someone out here that can assist.
