I am shopping for a IP Camera and found on the Vera wiki (http://wiki.micasaverde.com/index.php/IP_Cameras) the Z- series (sixth row under “cameras that work”), which claims to fit the Australian and New Zealand market. The camera has some uniques features such as SD flash memory, 2 way audio support on MAC, Mozilla and Chrome, and email support for gmail.
[quote=“Jetguy87, post:1, topic:166436”]I am shopping for a IP Camera and found on the Vera wiki (http://wiki.micasaverde.com/index.php/IP_Cameras) the Z- series (sixth row under “cameras that work”), which claims to fit the Australian and New Zealand market. The camera has some uniques features such as SD flash memory, 2 way audio support on MAC, Mozilla and Chrome, and email support for gmail.
I ended up buying the camera, but had some issues setting it up. The staff at ipcam-central.com helped me set it up and figure everything out; it works great.
EE-- you’re right, the gmail support is a really useful feature, and the Vera support is solid as well.
fall-line: Yes, ipcam-central helped me figure out how to configure Vera with the Pan/Tilt controls on the camera.
the-wal: Yes, but indirectly. I don’t need this function, but the camera provides external alarm contacts (either closed or open), which can be connected to a device like the aeon door window sensor, which also accepts those contacts, and could become part of the Vera z-wave environment. Ipcam-central has a downloads section that includes the camera’s manual, with more info about external alarms.
[quote=“Jetguy87, post:6, topic:166436”]fall-line: Yes, ipcam-central helped me figure out how to configure Vera with the Pan/Tilt controls on the camera.
the-wal: Yes, but indirectly. I don’t need this function, but the camera provides external alarm contacts (either closed or open), which can be connected to a device like the aeon door window sensor, which also accepts those contacts, and could become part of the Vera z-wave environment. Ipcam-central has a downloads section that includes the camera’s manual, with more info about external alarms.[/quote]
Thanks for the tip! The camera seems good, and it looks like the seller also offers Vera with Foscam and Smarteye support. It’s interesting-- I’ll probably buy that camera too.
I bought the SmartEye NC530 cam with a Vera 2. It has more features than the Foscam one, and works great—it is quiet and Vera can control PT and Patrol. E-mail Motion Alarms work with gmail and video FTP too. It also has contacts to connect to external alarms.
Okay… slightly off topic… but the Smart Eyes mention “Pelco support” Pelco seems to be a brand camera. Whats so unique about them that another company I guess would emulate a pelco? I may be way off in my interpretation of ‘pelco support’. Its just that it caught my eye.
BTW… this does look too cool, this thread may have pushed me off the fence to get an outdoor camera. Its got a lot of built in / standalone features yet still integrates with Vera. Thanks!
The Pelco support is a popular standard for Pan/Tilt/Zoom, so you could use this with a pelco controller (joystick) to move the cam around manually instead of using Web soft buttons
Wow… ipcam-central is a very helpful company! I emailed them with questions about their outdoor version NC532W. Responded back within 30 minutes. Wanted to know if it came with onboard flash. Was told ‘no’ because it was in a waterproof enclosure there was no ‘user accessible flash card’. However they said they could custom order/build one for me with 4gb flash onboard and the price wasn’t the much more (and they stated that this camera worked with vera as well). I figure it may have the slot onboard, but the last thing I want to do is take a new camera and void the warranty on it.
I wanted the onboard flash for local image storage for standalone use. Will post more later.
Hi, I just noticed that IPCam-central.com published instructions on how to connect the NC530 and the Foscam cameras with Vera. They even ship the plugin files embedded in the Vera2 controller:
Hi all.
I guess im in the same boat as Jeff.I bought this cam from smarthome.com.au and have been unable to use it…If some one is willing to share the xml for the smarteye cam…that would be really great or some setup instructions on how to install it…
[quote=“myhomeserver, post:11, topic:166436”]The Pelco support is a popular standard for Pan/Tilt/Zoom, so you could use this with a pelco controller (joystick) to move the cam around manually instead of using Web soft buttons[/quote]Sorry for digging up an old thread but it was the only reference to Pelco I could find.
I just picked up a new exterior camera that uses the Pelco D / Pelco P protocol. It’s up and running and controlled via my DVR but after seeing this article http://www.codeproject.com/KB/cs/PelcoPDinC.aspx I pondered the thought of using Vera to schedule control of the cameras presets.
