"timezones.json loaded
system database loaded
Internet check status: ok
Local database returned invalid JSON.
ERROR loading local data: remote access service is not active.
ERROR loading local data: remote access service is not active "
I get these errors when I go to my findvera.com, after I login.
For some reason your vera isn’t seeing a internet connection make sure you can see the videos on vera when logged in locally.
Is the power light on Vera solid? If it is, you have internet connection. So while you’re connected locally on your LAN, go to the findvera tab in Vera’s setup and be sure it’s active.
