Yale YDD424 with Vera
This worked for me.
Replace VariablesSet with the text below
1-Silent mode (1-3),1d,2-Auto relock (0 or 255),1d,3-Relock time (5 or 255),1d,4-Wrong Code Entry Limit (1-7),1d,7-Shut down time after wrong code entries (1-255),1d,8-operating mode (0=normal 1=vacation 2=privacy 3=no rf),1d,
It seems like variable 6 is the culprit. You can also try delete it under device options
[quote=“Eric Tan, post:21, topic:191422”]This worked for me.
It seems like variable 6 is the culprit. You can also try delete it under device options[/quote]
Thanks will try if it decided too go crazy again.
