I’ve spent countless hours searching, and added/removed the lock dozens of times, but still it would not send me an email notification when the door is locked/unlocked or even a wrong pin entered.
I have vera lite, and yale real living push button…
Everything else works, Notification test works, mios lock/unlock …
If someone has it configured, Can you please tell me what i’m missing here?
If the lock is working correctly within Vera but you are not getting notifications than I would bet that you are not entering the configured user # in the notification setup. It was not clear to me the first time and I read it in one of the lock forums. I’m away right now so can’t provide config pics right now but can in a few days if this doesn’t help.
Thanks for the reply!
Everything works correctly, i can lock and unlock from mios, and when i do i get the notifications.
But if i do anything on the door, there’s never a notification (Bad pin, lock, unlock, pin entered …) i never get a notification if it’s done on the door.
I contacted micasaverde’s support, and the agent suggested a beta firmware update.
As soon as the system was updated with the new firmware, everything worked correctly!
