Yale Real Living Deadbolt scene to reset pins
I noticed that the Yale deadbolt has a reset (to factory setting button). This is the scenario where someone is legitimately in my place but resets the deadbolt to factory settings to set their own pins so they can return later.
How do I set up a scene to rewrite my master pin and other user pin settings for the bolt each night?
Sent an email to Yale technical folks.
Response was that master pin cannot be reset with Vera. Only way to reset was to remove the inside escutcheon from the door.
So sounds like the only work around would be to run a test on the lock each night (ie maybe modify a pin) if test fails, master pin is compromised.
I did ask the Yale Technical person if they would consider have one of their team members join our forum. He responded that they would discuss in their team meeting. I don’t see a downside here…
