Yale Locks
Hi Everyone I got a Veralite and have added a yale lock to it (the push button one, not touch screen) , works really good, so good I decided to go get another, but its been a struggle to get the vera to get passed “purging association”. Is it possible the other lock is interfering with the setup of this one? I’ve read through the forums here about installing it via full power inclusion, but I assume that’s if you have a Vera verses a vera lite as I don’t see that option. Any thoughts would greatly be appreciated.
Frank
Do you have a good location, near to controller or a repeating node on the network?
no repeater on network , i’m thinking maybe better to remove lock and do the setup with it sitting next to the vera then installing it?
you can try that, but when you relocate it remember it may not work.
If you try it, remember to do a ZWave heal on your network after you put it into its location.
you need to do this any time you physically move a device in order to re-route the optimal path for s signal t go from device to vera and reverse.
I believe this is not a good strategy for including devices, because the neighbor list would be incorrect, and the device may not work altogether in its final place. Moving Vera to the device would be better.
very unlikely
yes, you should use full power inclusion regardless of your Vera model, it’s under the “add devices” / “advanced Z-Wave devices”
if you still get this problem, I suggest doing the following:
  1. try full-power inclusion and give some time to finish the inclusion process.
  2. if it doesn’t work, bring Vera closer to the lock, and do the inclusion there
  3. otherwise, the lock may be out of range, try to add more intermediate nodes that support beaming
Thanks for the info, i’ll give that a whirl, really appreciate your insight i’ll report back whats the outcome
Hello Lupo,
I had the exact same issue. I installed one at my kitchen back door and one in my front door. The distance from Vera to the kitchen door is 30 feet north and the distance to my front door lock is 10 feet North East.
The kitchen door lock installed and synced without any problem but the front door lock didn’t work at all. I tried over 40 times over 2 weeks before I gave up.
Then I called support and here is what I learned and what we troubleshooted.
A) When you disconnect Vera and go into battery inclusion mode the sync process is NOT complete when the lock says complete. The manufacturer recommends to let it sit next to the lock for at least 5 min. My tests showed that 2 min is sufficient but don’t take any risk here and go with the 5 min please.
B) Despite it synced when I plugged Vera back into the power and ethernet mode in the final location, it stopped in various startup phases ranging from Setting up users, securing communication, etc.
C) You will find in this forum one user where a baby camera interfered with the Z-wave so I disabled our wireless baby camera completely and it didn’t help either. Was worth a try.
D) I took the Z-wave modules from both door locks and switched them to check if the front door lock module is faulty so I did a factory reset on both and tried it again. Again, Kitchen Door lock worked, but Front Door lock did not.
E) I called support again and they shipped me a replacement lock as they had no other ideas either
F) Then I took a long ethernet cable and a long power cable and I powered up Vera right next to my front door and it worked. So instead of using the battery inclusion mode, I used the in place inclusion mode right next to my door. When I put Vera back where she should be, it stopped working again. This implied to me that something is blocking the communication. I used the original lock and the replacement lock for this test. Outcome was the same for both locks at the front door.
G) At this point in time I was considering to move my Vera to a different location but then I read about “Beaming” which is a required feature for battery operated Z-wave devices. I checked all my Z-wave devices and none of them supported beaming at that time. I was going to buy a new Z-wave controller for my Living room lights anyway so I purchased one which supports beaming.
Here is the outcome:
The 10 feet between Vera and the front door is not too far but in between we have our washing machine and dryer which clearly blocked the communication in some form or fashion. The new Z-wave scene controller I purchased is NOT in line so I used the neighbor path option to connect to the front door lock via the new Z-wave controller and voila it worked. I tried both the original and the replacement lock and with the new z-wave scene controller I was able to make both of them work so there was no need for a replacement lock.
This shows yet again that the more devices you add to your Z-wave network the more robust it gets with the exception of having to account for beaming support for battery operated devices.
You might not have the same issue but I hope my steps above might help you to resolve your issue.
P.S: I hope you ordered the free upgrade to secure your locks against the paper clip hack YALE REAL LIVING LOCK PAPERCLIP HACK - YouTube
