Yale Lock Scene Trigger Issue
I have 2 Yale Locks. The one on my front door I have had for about 2 years now. I just purchased another. There is a trigger you can setup for whenever a Pin code is entered you can do something. I originally entered this scene in UI5 now that I am running UI7 and want to add an additional trigger for my scene, I can no longer have a trigger for when the master code (#0) is entered. It only shows for Pin code #1 and above in the drop down. Is there a work around for this? Is there some way to manually change the Pin Code # in the trigger?
