Yale Lock and Alerts
Howdy All,
I have micasa UI5 1.5.408, and a Yale Real Living Deadbolt with Zwave. It is very flake when reporting locks,unlocks and pin code entries. I have used some of the push notifications etc. No avail sometimes it will report a trigger, and other times it will not. Any ideas?
known issue – firmware 1.5.408 doesn’t play well with Yale locks, contact MCV support, they should link you to a beta firmware that fixes this.
I’m using UI5 on Vera3 with firmware 1.5.622, and I am having the same problem with the Yale locks.
which issues exactly? the ones mentioned here are related to 1.5.408 and they got fixed on later releases …
which issues exactly? the ones mentioned here are related to 1.5.408 and they got fixed on later releases …[/quote]
As the first poster said, “It is very flake when reporting locks,unlocks and pin code entries.” Although my locks report locked and unlocked status correctly. My locks don’t notify on any PIN code entries.
