Hi everyone,
I’ve recently setup datamine and I’m logging all types of data but I’m trying to create more useful graphs and am having some trouble.
I am mainly reviewing temperatures and wattage. A good example of an issue I’m having is with a graph of a thermostats goal temperature and actual temperature. Since these #s are usually close to each other, I want them both to have the same Y-axis on the chart, but instead they each have their own at different scales. This makes it difficult to see when the temperature reaches the goal temp since they are far apart on the chart.
Any tips in controlling Y-Axis on charts? I tried changing the “Units” configuration item but didn’t see a change. If that is the key, is there any documentation around that? I tried numerous searches for both with no luck.
Thanks!
