X10 with Alsteon - missing file I_InsteonX10OnOff.xml ???
I’ve been converting to Alsteon today, and I have a couple stragler X10 devices I’m trying to load.
I found these instructions: Altsteon / Code / [795083] /altsteon-lua/altsteon_x10_instructions.txt
I was able to find the D_BinaryLight1.xml by Googling around (so I can see the device in my MCV device list), but the other mentioned file is no where to be found: I_InsteonX10OnOff.xml
In fact, according to this page it was just removed?
http://sourceforge.net/p/altsteon/code/ci/a3ac15d5e8f5ea0ba28b87f15c51910047a9c214/
Anyone know where I can find that file? Seems to be my missing link.
Thanks!
-dan
I am not sure if this is operational. I know that about a month ago fba was able to fix the timing of X-10 commands to get simple on/off commands to work from the altsteon command line, which I have been able to do. I don’t know if he has finished the UI implementation yet. He mentioned that he had a cursory UI tile started but haven’t heard anything for about a month.
