Is there any way to differentiate between an X10 device status update and a status change?
As far as I know at the moment Vera can only detect status change for an X10 device.
If a device has the status “On” in Vera and a X10 command is received with an “On” command for the device Vera will NOT notice the command at all?
What I’m trying to do is to trigger a scene from an “On” command even if the device status in Vera already is “On”.
Any suggestions?
Br,
Tomas
