I have a Fortrezz WWA-01AA leak/freeze detector that is beginning to drive me crazy. I have it set up in my crawlspace to monitor the pressure tank for leaks and freeze conditions. It seems the sensor triggers an alarm at 39 degrees that comes thru as a leak alarm. I have two questions about this.
Why does it send a leak alarm at 39 degrees?
How do I change the 39 degree default temperature to something different?
I would like to set the default to something like -10c then question #1 becomes irrelevant. I believe this is parameter 1 but I cant figure out how to make this a negative value or exactly how to change it at all. Thoroughly explain this to me because this whole bytes, hex, dec is all new to me.
I live in San Diego, so I’ve only used the water leak sensor for alarms.
I noticed this though when I added 5 water sensors to the Vera.
The WWA-01AA supports two association groups. A maximum of 5 associated devices are allowed in
each group.
The WWA-01AA sends the Basic Set Command to the associated nodes assigned to Group1 to convey that a Water Alarm is
active. If no nodes are assigned to Group 1, then a Binary Sensor Report (value = 0xFF) is broadcast. The reports are sent at
regular intervals while the water alarm is active. When the water alarm is cleared via the button, one additional report (with status =
no alarm) is sent.
The WWA-01AA sends the Basic Set Command to the associated nodes assigned to Group2 to convey that a Freeze Alarm is
active. If no nodes are assigned to Group 2, then a Binary Sensor Report (value = 0xFF) is broadcast. The reports are sent at
regular intervals while the freeze alarm is active. When the freeze alarm is cleared due to temperature rise, one additional report
(with status = no alarm) is sent.
I found the link on my own but it is Greek to me. Association groups, nodes, whether or not they are present and the info in the link about changing temperature are all over my head right now. That is why I’m asking for help.
More specifically how do I change the temperature to a negative value using the link to provided. There are a lot of options in the drop down box and when I enter one as the parameter I do t see anything under the current value colum. None of it makes sense to me and I can’t seem to find a beginners guide to this sort of stuff.
Let me start by saying, I don’t own one of these and the only reference to configuration parameters that I was able to find was for the newer model WWA-02. There is a strong chance that the parameters are the same. Hopefully your unit came with a manual that discusses the parameters.
According to the specs I found there are two configurable parameters:
Paramter No. 1 Size 1 Default 4
Name Low Temperature Trigger Point
Values -10 degrees - 127 degrees
Paramter No. 2 Size 1 Default 70
Name High Temperature Trigger Point
Values -128 degrees - 70 degrees
To configure these parameters, click the wrench on the WWA-01. On the resulting configuration panel:
Click the Device Options tab.
Click the Add configuration settings button.
In the Variable field type 1.
Click the Monitor only dropdown and choose 1 byte dec.
In the Desired value field type 0. – I’m unsure of how to configure a negative value in this case. -10 decimal may work. But, -10 decimal would be 0xFFF6 which is 16 bits. This parameter is a single byte(8bits) field, so I don’t know how they would do it.
Click the X to close the configuration panel.
Click Save in the upper right corner.
And @PhillipP, after a few months banging your head on working on this fun but complicated system…what @Z-Waver mentioned will be the easyier tasks. I know it seems tough now.
Immersion and persistence will lead to happy automated home.
Fortrezz responded saying the WWA-01AA is not configurable and is a freeze alarm only. They did state that the WWA-02 could be configured with a negative number.
It is located in the crawl space where my well pressure tank is located so no adjustability is a pain. I get alerts constantly because the temperature dips below their 39? set point frequently. The good thing is I can’t hear the alarm in the house. That’ll teach me to read up on what I’m buying before purchasing. I read the item specifics on amazon and misunderstood it.
Z-waver, you are correct to be sceptical about entering negative values. I replaced the unit with a wwa-02aa and I cannot configure it with a negative value. Another email to tech support and hopefully they’ll have an answer.
If you haven’t heard back form them yet, you might want to try using 1 byte hex and then a value of F6 for -10 degrees. They may be wrapping the values rather than relying on explicit double byte values.
Interesting. Thanks for the information guys. I had done some reading and found out it split 255 in half but couldn’t figure out how to enter it as a negative value. Every thing I read had the values expressed as 1s and 0s.
I haven’t heard back from fortrezz yet.
