I’m new here, just got my first Vera (Plus) a few weeks ago and have had some fun writing my first scenes. I wanted to keep and graph my sensor readings - which Datamine2 is obviously great for. I did however want to have my readings online, especially to monitor things when away from home, so I spent some time getting Vera to write to Ubidots (www.ubidots.com). The choice to use Ubidots was purely down to personal preference - i looked at Thingspeak, but I don’t like the fact it seems to be very closely linked with Mathworks, same thing for Xively which seems to have gone to a pure enterprise model after the Pachube / Letmein acquisition.
If anyone finds this useful my first go at a Ubidots update scene is as follows (code is maintained on GitHub - dagsonstebo/Vera-Lua: Vera Lua/Luup scenes and the readme has a bit more information about configuration and usage):
Vera Lua scene for reading sensor variables and writing to Ubidots.
Configure Ubidots token in variables as well as all sensor readings in the
VERAVARS array, and use code in the Luup section of the Vera scene.
-- Variables
local UBIURL = "http://things.ubidots.com/api/v1.6/variables/"
local HEADER = "\"Content-Type: application/json\""
local UBITOKEN = "UbidotsTokenHere"
local FAILVAL = 0
-- Populate all variables to be read.
local VERAVARS = {
{ ID=10, NAME="KTTEMP", VARID="UbidotsVariableID1", SVC="urn:upnp-org:serviceId:TemperatureSensor1", VAL="CurrentTemperature" },
{ ID=11, NAME="LRTEMP", VARID="UbidotsVariableID2", SVC="urn:upnp-org:serviceId:TemperatureSensor1", VAL="CurrentTemperature" },
{ ID=12, NAME="KTHUMID", VARID="UbidotsVariableID3", SVC="urn:micasaverde-com:serviceId:HumiditySensor1", VAL="CurrentLevel" },
{ ID=13, NAME="LRHUMID", VARID="UbidotsVariableID4", SVC="urn:micasaverde-com:serviceId:HumiditySensor1", VAL="CurrentLevel" },
{ ID=14, NAME="KTLIGHT", VARID="UbidotsVariableID5", SVC="urn:micasaverde-com:serviceId:LightSensor1", VAL="CurrentLevel" },
{ ID=15, NAME="LRLIGHT", VARID="UbidotsVariableID6", SVC="urn:micasaverde-com:serviceId:LightSensor1", VAL="CurrentLevel" }
for k,v in pairs(VERAVARS) do
-- Read each value.
local RETVAL = luup.variable_get(v["SVC"], v["VAL"], v["ID"]) or FAILVAL
-- Build curl command
local UPDATEURL = UBIURL..v["VARID"].."/values/?token="..UBITOKEN
local POSTDATA = "\'{\"value\":"..RETVAL.."}\'"
-- Execute curl command.
COMMAND = "curl -X POST -H "..HEADER.." -d "..POSTDATA.." "..UPDATEURL
os.execute(COMMAND)
-- Log each reading.
luup.log("Ubidots: "..v["NAME"].." = "..RETVAL)
luup.log("Ubidots: update complete")
return true
Happy with any feedback on this. I’m fully aware the topic of writing plugins comes up on a regular basis in these forums and I’ll consider this in the long run - whilst I’ve been doing IT and scripting for a couple decades I don’t consider myself a developer so I’ll take it one step at a time. A couple of things I’ve considered:
[ul][li]Use variable_watch to only write sensor readings when they are updated.[/li]
[li]I also considered creating new sensor variables containing the Ubidots variable IDs, then loop over all variables (something like luup.variable_get(“ubidots”, “ubivarid”, #) ) and write each as required. I however found no way to to read each sensor reading using only the variable ID without knowing the service identifier, and whilst it seems you could potentially use luup.attr_get (‘device_type’, #) to parse and create this it doesn’t seem particularly elegant. [/li][/ul]
If anyone has any suggestions I’d be very interested.
Regards,
Dag
