WORKAROUND - Triggers from scene removed but still present in VeraLite
Hello ,
I have created triggers for a Fibaro wall plug to get notifications “Wall Plug OFF” , “Wall plud ON” in my Veralite .
The I deleted them but :
  1. the triggers have been removed for the Dashbord/Triggers view = OK
  2. there are still in the system = NOK and displayed in Imperhome application as a consequence
Thank you for an advice/solution.
Have you restarted the system and checked they’ve really gone?
Or try it with an HTTP request as described here
[url=http://wiki.micasaverde.com/index.php/Luup_Requests#scene]http://wiki.micasaverde.com/index.php/Luup_Requests#scene[/url]
Thanks a lot akbooer.
Yes I had restarted the system and the issue was still present.
Your suggestion to delete the scene using the Luup request has been successful , no now no extra scenario anymore
I Had to remove the Fibaro Wall plug from the ZWve network in order to make a new fresh test.
But I has to again delete manually 2 existing triggers in the VeraLite
Something should be wrong with the VeraLite when suppressing this module
