Where can I find information on the internet how to do the wiring of my Home-Pro devices (how to wire up the Auxiliary Switch connetion(s) om devices? Do we need to use them? and if, when and how?
Auxiliary Switches for the Home-Pro devices are used in 3-way or 4-way set-up.
Single: ZDW103 (or ZRF113, ZRW103, ZRW113)
3-Way: ZDW103 (or ZRF113, ZRW103, ZRW113) + AS101
4-Way: ZDW103 (or ZRF113, ZRW103, ZRW113) + AS101 + AS101
5-Way: ZDW103 (or ZRF113, ZRW103, ZRW113) + AS101 + AS101 + ZTW103
6-Way: ZDW103 (or ZRF113, ZRW103, ZRW113) + AS101 + AS101 + ZTW103 + ZTW103
Hope that helps - Happy New Year’s 8)
Any wiring diagrams with 4-ways… for older homes?
Whose devices are you planning on using? The setup for ACT/Homepro and GE/Jasco is different then the setup for Leviton Vizia RF + or Intermatic Intouch or HomeSettings devices. 8)
Leviton Vizia RF+, I’ve notice depending on what type of wiring e.g not having a neutral wire you need a different slave module is this true?
