I have a switch outlet in the study that have 2 switch. One switch is for the fan and the other is for the light. The fan switch have a copper wire (ground) and 2 black wire. The light switch have a copper wire (ground), red wire, and a black wire. Also there is bundle of white wire (neutral) wire together. How do i wire this to make it work on the Jasco 45609?
You’ll need to jumper a white wire to the neutral connection on the switch and figure out the hot with a multi meter to determine line np and load.
Yep, you have to get the neutral and the hot to the switch to power it. Sounds like the black- black and red-black are the ones the need switching. Just test as the other poster suggested.
