Has anyone got a recommendation for a wired motion sensor that I can use outside (in a covered porch, so should stay dry).
I would like to use it in combination with a door sensor to turn on the porch light when leaving the house, and to turn on the interior lights when approaching the house.
I looked at the HSM100 but am in the UK and no-one seems to sell it.
Hi Have you had any luck? This seems to be such a simple task? All I’m asking is a simple trigger to turn on a light(s) but yet I cannot find anything on it either. It seems strange…you can set up multiple scenes, let you know if you have a flood, tell you the humidity, and thousands of other tasks. But I cannot get a device to turn on my lights via motion.
What I’m looking to do is have the light be able to turn on via motion sensor and if I choose to be able to turn (the porch light) on from the inside (manually) as well
hoping someone can help, as I’m in the dark as of now …literally
For now I am thinking of using a simple door switch combined with the Aeon Labs Multisensor. That sensor is battery operated (I’d prefer not to have to mess around changing batteries) but it’s waterproof so should be OK.
