Wired relay board control
I realize that Vera is all about wireless system, but it happens that I do have cabling to 22 of my blinds already in the walls. I wonder id I could use it. For that I need a relay board that is supported by Vera, with as much 230V relays as possible. Something similar to the EtherRain just for 240V. Is there such a device with community support from Vera?
So far I found one small board that has 5 relays and Eth port and is controller over the SNMP. It is cheap at around 50 USD, and here is some info on it ftp://ftp.wirelesslan.pl/man_lan_en.pdf. Is there any support in VERA for controlling devices over SNMP?
Regards
Maciej Eckstein
I guess you could use this Plugin:
Plugin:
http://code.mios.com/trac/mios_iorelay
Forum:
http://forum.micasaverde.com/index.php/topic,7589.msg48846.html#msg48846
See also the quad relay board and plug-in @drag0n is using.
Sherlock:
The relays from the etherrain (or other device) could activate larger relays that switch the higher voltage and load. Cube relays (http://www.automationdirect.com/adc/Shopping/Catalog/Relays_-z-_Timers/Electro-Mechanical_Relays/Square_-z-_Cube_Relays,_Plug-In,_3A_-_15A_(78x-z-_Qxx-z-H78x_Series)/General_Purpose,_3A,_5A,_10A_(QL2_-z-_QL4_-z-_QM2_-z-_QM4_Series)) will do the trick and can be rail mounted for tidy installations. Select relays by coil voltage and switched voltage/load
Thanks for the info!
The NCD board with 32 relays look sweet but is a bit steep at 650 USD.
The 4 relay serial board is best price, but I’m not sure if the Vera would handle 12 of those connected over USB? as I need 44 relays for 22 blinds
I have no problem with driving the separate relays from some other board. In fact this is my alternative design with PLC and 3 x 16 output slices. That is also very economical, as quality relays are around 5.5 Euro each.
If not relays maybe you can give me some leads to the I/O bords that have lot output ports for driving the relays.
I have no personal experience with them, but there are a number of people on ebay selling ethernet controlled 16 relay boards for about $140. Search for “Ethernet 16 Relay Module” or similar. One of the companies is http://denkovi.com/.
They claim the relays are rated at 10A/250VAC.
I would expect that it would be pretty easy to get that working with Vera, but you might have to write a little code.
That is excactly what i was looking for! Thanks,writing some code is no problem, i just now wait for vera3 to arrive.
See also
http://www.koukaam.se/showproduct.php?article_id=1504
http://www.koukaam.se/showproduct.php?article_id=1502
the nice thing is, that you have 4 Switches in one box. How to control the Boxes you find in the koukaam forum.
MFG Karl-Heinz Schneider
not sure to be in the appropriate topic, but have a look to this kind of board :
labotronik.com/lang-en/ethernet-relay-card/19-ip-ethernet-8-relays-card-us.html
what to you think about it ?
I think it’s better to have only one board instead of two parts, and there is a case too.
the price sounds good if you see specifications.
You cant beet denkovi solution on the price at 135 usd per 16 ports and already in EU so cheap delivery.
2 boards setup is a bit clumsy but since I need 44 relays I’ll make economy on the numbers of boards itself requiring only 3 sets not 6 as for 8relay boards.
Sherlock (or anybody else with knowledge of Denkovi boards) -
I too am considering some of these Denkovi ethernet relays for blind controls. Were you able to succesfully program Vera to control these relays?
Thanks for the help.
