are there a list of wired cameras that will work with Vera. I am switching from ADT and have a one wired camera from that system I would like to integrate into my Vera system.
Radjin
Radjin
The camera support in vera is based of of http control. So if your camera has access to an http interface / api, you should be able to set it up. Mainly you’ll need to have some sort of http url to retrieve the camera image.
