I have a wired alarm system with every window and door sired with contact closure magnetic switches. I’d like to remove the very basic control panel and connect each input via Z-Wave to VERA. Is there a multi-channel contact closure to Z-wave interface that will send sensor data to VERA?
There are a number of alarm systems that can be directly interfaced into Vera, so if you list what you have people may be able to identify if it is compatitable already. If it isn’t, it may be cheaper and more reliable to upgrade your alarm to one that is.
Here is a starting point for compatitable hardware, it isn’t completely upto date
http://wiki.micasaverde.com/index.php/Supported_Hardware
