Wire connection in Fibaro Double Relay
Trying to connect my double relay to a Fibaro double relay. Need some guidance on this:
Below is my switch box:
Red and brown: live
Blue: neutral
Below is the Fibaro guide:
Based on the guide, am I suppose to add the live 1 and live 2 to Q1 and Q2 respectively?
Which is the intended wire for L on Fibaro?
Thanks so much!
You need to post a better photo - your switch should have three “live” wires, maybe there are two brown ones?
(L) Input always on live
(1) Output from switch 1
(2) Output from switch 2
You can check with an electrical screwdriver to see which change when you flip the switches. There may not be a neutral attached to the switch (unless purely for joining purposes) - but with luck it’s in there, you may be able to tell by checking the neutral colour at the light fitting.
Once you know that:
[ul][li]split the neutral wire and take a feed to the neutral of the Fibaro (I wouldn’t use the Fibaro terminal to join the split wire, they’re not that big, use a push fit cable joiner)[/li]
[li]move the switch output wire (1) to Fibaro Q1 (i.e. the first load)[/li]
[li]link Fibaro S1 to switch output (1) with a new bit of wire[/li]
[li]move the switch output wire (2) to Fibaro Q2 (i.e. the second load)[/li]
[li]finally, link the live feed at switch (1) to feed the Fibaro “L” terminal with a new bit of wire[/li][/ul]
