Hi Everyone!
I got a Everspring SM103 Window Sensor. I can’t get it into my Vera System. I also don’t know how to put it into Inclusion Mode, so I have to take out the batteries and try after 20 min again.
Any help?
Thanks! ![]()
Hi Everyone!
Any help?
Thanks! ![]()
I got it to work.
Just in case anyone has the same issue. When I initially put the batteries, I wasnt ready to pair. So, I took out the batteries for 20 min. Put them back on, when it started flashing I put the Vera on Inclusion mode, and then I press the back metal thingy three time fast, and it worked.
Here’s the manual for this sensor with inclusion/exclusion procedure
http://www.smarthomeusa.com/product_images/h/HomeSeer/HS-SM103-1/HSSM1031_Guide.pdf
