Window Covering Controls
When I first started using Veramate about 7 months ago I had access to all the same controls that are shown from my Vera 3/UI5: See 1st photo
For the past several months I can only get a Slider control using Veramate: See 2nd photo
What happened? I have only used device_type=urn:schemas-micasaverde-com:device:WindowCovering:1
[quote=“lemrock, post:1, topic:186595”]When I first started using Veramate about 7 months ago I had access to all the same controls that are shown from my Vera 3/UI5: See 1st photo
What happened? I have only used device_type=urn:schemas-micasaverde-com:device:WindowCovering:1[/quote]
This has always been the same (i.e, the image of the button you included hasn’t changed for window coverings). Only a slider is shown, but selecting the row switches it between on/off states (or last remembered state).
I wanted to keep the buttons compact, so I don’t show all possible buttons for a device or the interface would get quite messy. There is a job on the dev list to allow this to be configured though - so in a future release…
