Hello. New to the forum.
I have been reading up on posts, and am pretty confused.
My goal is to have an alarm system (DSC) that uses broadband connection and GSM as a backup. I want to be able to enroll in monthly monitoring.
I want to setup the alarm first, and then later move into some home automation using a Vera Lite.
I am looking at this package as a starter.
http://www.homesecuritystore.com/p-1307-kit495-15dcp01-dsc-alexor-2-way-wireless-alarm-kit-w-tl265gs-dual-path-communicator.aspx
- Will this system integrate with a VeraLite?
- If it does integrate what other components do I need to get this system to work with the VeraLite?
I know I am going to get the good old “please search” comments. I have been searching but this is a overwhelming subject for a newbie.
Ok after some more researching I now that the package I linked to above is not correct.
This system here seems more up my alley.
http://www.homesecuritystore.com/p-2162-kit32wireless2-dsc-kit32-16-wireless-alarm-system-w-vanishing-contacts.aspx
The 1832 board would have more than enough zones for my small house.
My question is now, can this unit be monitored via IP and/or GSM? If so I can’t figure that part out.
And now upon further research it doesn’t seem like I need IP alarm monitor.
I think going with GSM 2060 will be fine for monitoring and then I’ll do my personal interface using IP through the Vera. Does that sound right?
