I’m a new user, having just purchased a Vera2, a GE45601 remote, and a few lights and switches. The remote nicely gives me a bunch of scene switches, each with an “on” and an “off” button. Having paired things up, I set up some scenes and quickly found that the “scene on” buttons worked fine, but not the “off” buttons. So, I poked around some on this forum, finding several relevant threads, especially http://forum.micasaverde.com/index.php?topic=1960.msg7383. I understand that this isn’t entirely straighforward, because MCV needs to work around the fact that there really is no “scene off” in the z-wave spec.
It seems that there used to be two methods of using the scene controllers, but now there is only one, as noted in the release notes for 1.079 (http://wiki.micasaverde.com/index.php/Release_Notes). I think the way this now works is that all of the “on” buttons will generate the appropriate “scene on”, but all of the “off” actually generate the same event, a “scene on” for scene #0. This is how my remote is acting.
What I would expect is that the scene “on” and “off” buttons would generate the “activate” and “de-activate” events for the scene that I attach them to.
The forum thread I mentioned above references a MCV bug report on this, http://bugs.micasaverde.com/view.php?id=631. It shows as being resolved / closed, with all the dates in 1969. There’s another bug report, http://bugs.micasaverde.com/view.php?id=422 that seems to be open, showing as “assigned”, but at low priority.
So, a few question:
[ul][li]Am I simply doing something wrong, or misunderstanding something?[/li]
[li]What is the “de-activate” event? How / when is it ever triggered? Based on what I read, and what I see happening, I don’t see what can trigger it.[/li]
[li]Is there any remote that gets this right, or even can get it right?[/li]
[li]Others seem to have gotten the scene-off buttons to work, by re-adding the remote and other weird games. How can those work? Does anybody have the scene-off buttons working properly, generating the appropriate scene de-activate event?[/li]
[li]The referenced thread is from September 2009. It’s now 1.5 years later. Is micasaverde working on a better solution? I can think of several workarounds that would do the trick, some of which are suggested in the referenced thread.[/li][/ul]
