Hello!! Is there any way that the vera can control wifi (not Z-wave) devices like socket wall plugs, wifi sensors and all these stuff?
I was thinking connecting a USB WiFI adapter to veralite.
You most likely would need to install drivers for that stick which may not be available for the VeraLite so it would not work.
Thanks for the reply BOFH! I was sure about the drivers you mentioned but as i can see, WiFi devices are more cheaper than Z-wave. So i wonder why no one tried to make a suitable plugin for that purpose.
Actually someone did make a plugin for WEMO devices a while back. Which I believe use WiFi
See http://forum.micasaverde.com/index.php/topic,14508.0.html
