Wide Range multi-sensor
Hello Fine folks of MCV Forums,
Does anyone knows of a wide range multi sensor? I’m looking more specifically at these ranges:
Humidity: 5% to 98%
Temp : -20F to 180F
If someone knows, can you point me to them?
Thanks,
Similar to this came up last year and none if the multi sensor provided that range capability. If I remember correctly, it was advised to look at the one-wire sensor for temp measuring
but nothing in the z-wave multi sensors.
Have a look here
http://forum.micasaverde.com/index.php?topic=11421.0
