Why won’t the following conditions fire when ANY door is opened or closed? I’m sure this is basic PLEG logic, but can’t get past it.
Conditions:
DoorsOpen No MBR_Door_Open OR KIT_Door_Open OR ENT_Front_Open OR GRG_Entry_Open true 2014-03-07 13:34:16.432 0
DoorsClosed No !MBR_Door_Open OR !KIT_Door_Open OR !ENT_Front_Open OR !GRG_Entry_Open true 2014-03-07 13:34:16.435 0
Triggers:
MBR_Door_Open MBR - Sliding Door Contact Sensor armed is tripped false 2014-03-07 13:48:47.888 2014-03-07 13:50:20.929
GRG_Entry_Open GRG - Inside Contact Sensor is tripped true 2014-03-07 12:20:23.005 2014-03-06 21:16:35.832
KIT_Door_Open KIT - Sliding Door Contact Sensor is tripped true 2014-03-07 10:54:12.677 2014-03-07 09:57:29.817
ENT_Front_Open ENT - Front Door Sensor is tripped false 2014-03-07 12:16:23.385 2014-03-07 12:16:28.245
Log:
50 03/07/14 13:50:20.928 luup_log:153: PLEG-153:TriggerPropertyUpdate:Tripped <0x2b821680>
50 03/07/14 13:50:20.929 luup_log:153: PLEG-153:TPU:Tripped :0=1 <0x2b821680>
50 03/07/14 13:50:20.929 luup_log:153: PLEG-153:TriggerPropertyUpdate:Name:MBR_Door_Open State:false Device:92 <0x2b821680>
50 03/07/14 13:50:20.930 luup_log:153: PLEG-153:EvalConditions:Multi Trigger:MBR_Door_Open <0x2b821680>
50 03/07/14 13:50:20.932 luup_log:153: PLEG-153:EvalConditions:Condition:BY_Alley_Gate_Open_TTS Trigger:MBR_Door_Open Result:false <0x2b821680>
50 03/07/14 13:50:20.933 luup_log:153: PLEG-153:EvalConditions:Condition:BY_Lawn_Gate_Open_TTS Trigger:MBR_Door_Open Result:false <0x2b821680>
50 03/07/14 13:50:20.936 luup_log:153: PLEG-153:EvalConditions:Condition:DBR_Left_Window_Open_TTS Trigger:MBR_Door_Open Result:false <0x2b821680>
50 03/07/14 13:50:20.954 luup_log:153: PLEG-153:EvalConditions:Condition:DBR_Right_Window_Open_TTS Trigger:MBR_Door_Open Result:false <0x2b821680>
50 03/07/14 13:50:20.955 luup_log:153: PLEG-153:EvalConditions:Condition:DHW_Crawl_Open_TTS Trigger:MBR_Door_Open Result:false <0x2b821680>
50 03/07/14 13:50:20.959 luup_log:153: PLEG-153:EvalConditions:Condition:MBA_Window_Open_TTS Trigger:MBR_Door_Open Result:false <0x2b821680>
50 03/07/14 13:50:20.961 luup_log:153: PLEG-153:EvalConditions:Condition:MBR_Door_Open_TTS Trigger:MBR_Door_Open Result:false <0x2b821680>
50 03/07/14 13:50:20.964 luup_log:153: PLEG-153:EvalConditions:Condition:UBR_Window_Open_TTS Trigger:MBR_Door_Open Result:false <0x2b821680>
50 03/07/14 13:50:20.967 luup_log:153: PLEG-153:EvalConditions:Condition:DR_Window_Open_TTS Trigger:MBR_Door_Open Result:false <0x2b821680>
50 03/07/14 13:50:20.970 luup_log:153: PLEG-153:EvalConditions:Condition:LR_Left_Window_Open_TTS Trigger:MBR_Door_Open Result:false <0x2b821680>
50 03/07/14 13:50:20.972 luup_log:153: PLEG-153:EvalConditions:Condition:LR_Right_Window_Open_TTS Trigger:MBR_Door_Open Result:false <0x2b821680>
50 03/07/14 13:50:20.975 luup_log:153: PLEG-153:EvalConditions:Condition:KIT_Door_Open_TTS Trigger:MBR_Door_Open Result:false <0x2b821680>
50 03/07/14 13:50:20.976 luup_log:153: PLEG-153:EvalConditions:Condition:Water_SE_Crawl_TTS Trigger:MBR_Door_Open Result:false <0x2b821680>
50 03/07/14 13:50:20.977 luup_log:153: PLEG-153:EvalConditions:Condition:Water_SW_Crawl_TTS Trigger:MBR_Door_Open Result:false <0x2b821680>
50 03/07/14 13:50:20.978 luup_log:153: PLEG-153:EvalConditions:Condition:Water_MBA_TTS Trigger:MBR_Door_Open Result:false <0x2b821680>
50 03/07/14 13:50:20.979 luup_log:153: PLEG-153:EvalConditions:Condition:Water_UBA_TTS Trigger:MBR_Door_Open Result:false <0x2b821680>
50 03/07/14 13:50:20.980 luup_log:153: PLEG-153:EvalConditions:Condition:Water_KIT_TTS Trigger:MBR_Door_Open Result:false <0x2b821680>
50 03/07/14 13:50:20.981 luup_log:153: PLEG-153:EvalConditions:Condition:Water_GRG_TTS Trigger:MBR_Door_Open Result:false <0x2b821680>
50 03/07/14 13:50:20.982 luup_log:153: PLEG-153:EvalConditions:Condition:PerimeterOn Trigger:MBR_Door_Open Result:false <0x2b821680>
50 03/07/14 13:50:20.983 luup_log:153: PLEG-153:EvalConditions:Condition:PerimeterOff Trigger:MBR_Door_Open Result:true <0x2b821680>
50 03/07/14 13:50:20.985 luup_log:153: PLEG-153:EvalConditions:Condition:DoorsOpen Trigger:MBR_Door_Open Result:true <0x2b821680>
50 03/07/14 13:50:20.989 luup_log:153: PLEG-153:EvalConditions:Condition:DoorsClosed Trigger:MBR_Door_Open Result:true <0x2b821680>
