Why does Vera ask for electricity cost?
When I first set up my Vera it wanted to know what I was paying for electricity. But now that I’ve configured my entire network, I still don’t know what use it’s making of that information. Is there a plugin or something I’m missing that would show my electric usage?
In UI4 energy usage is visible when you enable remote access on cp.mios.com and when you have a device that is capable of reporting power usage (for instance, some Z-wave switches and all energy monitors).
On cp.mios.com, go to MiOS systems and find the Energy Usage tab.
If you don’t use this feature, then you can lie to Vera about your energy costs and no one will know.
Ah ha - thanks. I found the tab but it says “Not enough data for pie chart”. I guess none of my devices are SmartSwitches. If there was a way to tell Vera how much each node draws, then it could do the math easily enough since it knows how long each one is on.
Under the Settings tab of the Device, there is a field called Energy Used that can be used to manually specify the wattage of the attached device.
Wonderful! This is so cool - I keep discovering great features in this system. This is sooo much better than that Hawking gateway I had before. Thanks!
