Why do some plugin devices want to uninstall plugin when you delete 1 device?
The topic pretty much says it all. Some plugin devices when I try and remove them ask to remove the plugin as well. This doesn’t make sense. Examples:
PLEG: WILL let me delete just 1 device
MultiSwitch: WILL NOT let me delete just 1 device. I click the trash can and it asks if I want to delete the device and I say “OK”, then it asks me if I want to remove the plugin and all devices it created.
WOLPlusPing: WIL NOT let me delete just 1 device. Same as MultiSwitch.
Those are the only one’s I can really remember, but I know other plugins exhibit the same behavior and I’m just curious why.
Edit: I just deleted an XBMCState plugin and it also just let me delete just the device and not uninstall the plugin.
This is a reported bug:
http://bugs.micasaverde.com/view.php?id=2528
Work around:
http://ip_address:3480/data_request?id=device&action=delete&device=Device#
Thanks @Brientim
Sent from my Nexus 7 using Tapatalk
I hope that this bug will be fixed in the next version of the firmware. It is very annoying … for normal user.
