I’m new and i try to set up my Z-Wave Home Automation.
I start whit a Everyspring AN157-2 Switch → works without problems on the first try
then a Everyspring AD142-2 Dimmer Switch → works without problems on first try an the Everyspring AN158-2 Swich → is not detected
One possibility is that the device was included in a different Z-Wave network already. Perhaps it had been returned by a previous customer before being sold to you.
If so, exclude it first (with Z-Wave you can exclude with any controller), then it should be possible to include it.
[quote=“RichardTSchaefer, post:4, topic:173621”]You should still try to exclude them before including them.
It could be that the factory did NOT exclude them after their QA test.[/quote]
I have found this true several times with brand new equipment as stated by @RichardTSchaefer
