Who deactivate scene in vera and what for ?
Hi all,
Just a question.
I probably want to develop a plugin to deactivate some scenes.
What sort of scenes to deactivate.
I see in forum: lights, for me from now it’s windows blind, and a pump pool for maintenance.
And for you all, it’s what ?
The idea will be in a plugin with multiple on/off type but not only time might be interesting. Ergonomy too as i use an android smartphone and homebuddy.
A scan of all scenes will be interesting for selection.
Any idea remarks ?
Gilles.
Envoyé depuis mon Flashback 7.1 avec Tapatalk
No success, no one to answer ?
Envoyé depuis mon GT-I9000 avec Tapatalk
Would you clarify if you mean prevent the scene from running? Or pause / stop the scene once it's already started?
JOD.
sorry you’re right.
In fact I wants to know if some persons stop for a time or other reasons scenes.
I’m confront to deactivate some scene like my pool pump or the windows opening …
For that I code every scenes with a skip method and some virtual state devices.
What I found, is if it continu my dashboard will be a true christmas tree !!!
It’s for because of that I want to know the beahavior of users to try to found a solution (if there is one …)
I’ve not seen a means to pause a scene once it’s started.
I have however, suggested to MCV on several occasions to incorporate a luup event tab for each timed event, we would then have a means to prevent a timed event from running without having to make changes to Vera.
JOD.
