Which parameter indicates in group
Hi All,
Can you tell me what parameter indicates if a player is used in a group?
Currentstatus indicates a text parameter.
But I want it in a scene. play some music, but only when the Sonos is not already playing in a group. (using PLEG)
Thanks,
Danny
You can check that value of variable GroupCoordinator (urn:micasaverde-com:serviceId:Sonos1) is different from variable SonosID (urn:upnp-org:serviceId:ZoneGroupTopology).
Thanks,
That does the trick!
Danny
