Which lock will fit this door?
Which zwave locks would fit this door? The key dead bold controls the lower thumb locking mechanism.
The Dude
When you say “The key dead bold controls the lower thumb locking mechanism” does it physically control it (they are connected internally or on the other side somehow) or are they separate pieces that are just a matching set? My door looks just like that, and I just replaced the top deadbolt with a Kwikset one. Sure it doesn’t exactly match looks wise but works the same.
Both pieces are physically connected inside. Once you turn the key (dead bolt) all the way it controls lower lock to open the door.
Seams like pretty standard door lock. Just want to make sure any of the z wave dead bolts would work in this setup. I’m less concern about aesthetics, more about functionality.
I think it’s gonna depend on how they are connected. Any chance you can post a pic of the inside showing that?
It looks like a standard lock… I’d be surprised if the dead bolt controls the handle mechanism directly. If it really does, and you want it to stay that way - you are SOL for automation. Otherwise, you can simply replace the deadbolt with whatever unit you want.
