I want to se xiaomi and milight
Adding the ability for Vera or a Vera plugin to be listed by Alexa as a device that can trigger routines would be in valuable (rather than having to rely on tts through a speaker to trigger Alexa remotely).
It’ not in the list, but, it will be great if we will be able to commande the Samsung air conditionner with a wifi.
Sea this topic, in wich we have found some source code to do it :
[url=http://forum.micasaverde.com/index.php/topic,26523.msg217116.html#msg217116]http://forum.micasaverde.com/index.php/topic,26523.msg217116.html#msg217116[/url]
Mikl
When will the zwave poll start?
+1
There shouldn’t be a need for supported Z-Wave devices as they should ALL be supported out of the box without any need for tweaking.
If Homeseer can do it then why not Vera?
I just realize nobody was asking for MQTT native support.
That would be really helpful for ESP8266 /w Tasmota
I would love to see integration with the Lennox iComfort systems. Many of the more intelligent Lennox systems require you to use their thermostat preventing you from using more intelligent Nest or Honeywell systems.
https://services.myicomfort.com/DBAcessService.svc
Documented here: LennoxThermoPi-II/lennoxAPI.html at master · ut666/LennoxThermoPi-II · GitHub
Though this might just be for the older Lennox WiFi
The newer models are the S30 / E30 / M30 models. Though anyone with a system compatible with the older Lennox WiFi is also compatible with the newer models for a multi-hundred dollar upgrade price.
The newer models use https://www.lennoxicomfort.com url while the older Lennox WiFi model uses https://www.myicomfort.com
Motion devices in Vera to be able to trigger Alexa routines
Motion sensor triggers for Alexa
https://r.tapatalk.com/shareLink?share_fid=24007&share_tid=112943&url=http%3A%2F%2Fforum.micasaverde.com%2Findex.php%3Ftopic%3D112943&share_type=t
Blink camera system would be great for Vera. They are VERY LOW COST, free from subscription, don’t require a base station (just a tiny hub), and are very reliable…a perfect fit.
Yea Meross… i’d settle for a plug in… doesn’t need to be natively integrated… a no brainer… ZWAVE switch £30, Meross switch £10!
Actually all you need is the ability to kick off Alexa routines… for me that would be enough…
Amazon Alexa
Roomba
Samsung Aircon
Hi
Xiaomi (Roborock vaccum, camera, …)
Hik vision camera and video doorman
rtsp stream for camera
