Where to begin in automated blinds ?
I am quite new into the home autmation and vera world. Currently I am running a Vera 3 with UI7. I got Light Dimmer, Door Lock and Milight (with the plugin).
My next step is to add blinds. Current one are manual and needs to be replaced since parts are broken. While replacing them I want them to be motorized and integrated with Vera.
I am looking for blinds like this : http://www1.americanblinds.com/blinds/window_shadings/P-105395
Windows is 54inch wide and 62 inch height
I am open in brand and everything and some DYI, all I need is this look (Wife is firm on that point :wink: )
I got a power outlet nearby but I’d prefer not to see the wire.
Here’s my list of questions
  1. SHould I buy the blind with the motor built-in ? I have found some on Aliexpress running 12v motor
    If Yes
    a) What kind of controller is recommended ?
    b) How do you guys run wire to it ? What kind of Wire ?
    If No
    A) What motor should I go ? 12v, 24v DC or 110V AC ?
    B) Skill required to integrate motor into the shade ? and time estimation to do it (2h project or 5 day project ?)
  2. Anyone having shade running them under UI7 ? Any issues ?
  3. Favorite store in north america to buy required component ?
Hi Sturgeon,
I saw you send me a message, but I prefer to send it here so other can see it too.
The seller you saw on my other post on AliExpress sell pretty much everything you need. When I purchased my electric curtain with the rail, I asked the seller to have 120v motor instead of 250v. He ordered some motors from Dooya and when he received them, he sent my order to my home.
For the question about how to hide the motor wire, I only made a hole in the wall next to motor after installation and pass the motor wire in a cable plate cover without the cable thing in the center. Look clean and finish.
Everything is wires behind the wall.
I just saw the model you posted in your post. Send a message to the seller with the picture of the shade model (picture from the website link) and the width and the height of each of your screen on a sheet. He will make you a group price and send you the order all at once to save on shipping cost.
He can make custom size shade and model for really cheap.
Just to be sure to tell him that you want to control the motor with your home automation Hub, that way, he will put 4 wires motors instead of 3 wires motor that normally control with a remote control. This type of curtain can be integrate with Vera too, but no % control. Only full open and close.
Thanks, He is the first one I have contacted. But he was offering 2 wire DC12V motor. Since as saw a ton of option here I am lost in what is good and not good.
Currently James Smith (from Friend Group) offered me :
The motor is DC12V or DC24V, so it has two wires, one is Positive wire, one is Negative wire.
Since you motor is 120v, did you hook it directly in the gang box of a wall plug ? Since I do not master english completly I am not quite sure about the wall plate part. Can you give me further detail, are we talking about a cable raceway down to the plug ??
Anyway thank you for your answer
[quote=“sturgeon86”]Thanks, He is the first one I have contacted. But he was offering 2 wire DC12V motor. Since as saw a ton of option here I am lost in what is good and not good.
Anyway thank you for your answer[/quote]
?a sera peut ?tre mieux en Fran?ais. Je ne sais pas si ?a contrevient au forums, mais bon, c’est pratiquement la m?me chose que j’avais ?crit tant?t en anglais.
Le type de moteur que tu recherches pour le type de rideaux de ta photo n’est PAS la m?me chose que moi. Ce que j’ai acheter, c’?tait un rail avec un moteur au bout pour accrocher au plafond et suspendre des rideaux (plafond au plancher).
Dans ton cas, le moteur est diff?rent et est placer dans le top de chaque rideau ou est situ? le m?canisme pour faire monter et descendre le rideau.
Le moteur est plus petit et le poids du mat?riau utiliser pour le rideau ne n?cessite pas un moteur fonctionnant sur le 120 v pour le faire monter/ descendre. Du 12 ou 24v est en bien suffisant.
Par contre, il existe s?rement un module pour le contr?ler en brancher le moteur, mais c’est sur que c’est pas le Fibaro Roller Shutter. Ce module la a besoin d’un moteur avec un neutre, un pour ouvrir, un pour fermer et le ground.
Je vais regarder plus tard ce soir un mod?le de controller pour brancher le moteur et permettre de l’int?grer ? Vera.
Merci pour la reponse en francais habituellement je me debrouille assez bien en anglais. Par contre coter technique moteur beaucoup moins ! On peut cependant poursuivre en anglais :wink:
I was looking maybe for this controller : http://www.zwaveproducts.com/Zwave-Lighting/Z-Wave-In-Wall-Modules/Aeon-Labs-DSC14104-ZWUS-Z-Wave-Micro-Motor-Controller.html
But it says 3 wire installation and I am not quite sure it works for 12v motor … Again thanks for your answer it is really appreciated
[quote=“sturgeon86”]Merci pour la reponse en francais habituellement je me debrouille assez bien en anglais. Par contre coter technique moteur beaucoup moins ! On peut cependant poursuivre en anglais :wink:
But it says 3 wire installation and I am not quite sure it works for 12v motor … Again thanks for your answer it is really appreciated[/quote]
No, the product you posted wont work with your motor. The product you post control a motor On / OFF only but You cannot control the duration of the motor ON. Also, your motor doesnt have the wires needed. You need something like in this link, but please verify with the seller first or better, get a picture of the motor and the end of the wires, that way we will be 100% sure :
http://www.zwaveproducts.com/Zwave-Controllers/Zwave-Appliance-Control/ESI-DBMZ-Z-Wave-DC-Motor-with-Load-Monitoring.html
Exemple, for the living room, if you have like 4 or 5 windows to cover, you can wire them all together and need only need one this controller. (just verify it doesnt overload the maximum rate of the controller.)
Else, to reduce the cost, if you dont need % opening, but only open or close, you can ask the seller if he have a rf motor controlled by a remote. That way, you only need power to the shade and you can then open/wire the remote to two relays to control the open and close of the shades.
Thanks for the link … I find the controller a bit expensive considering the fact the it is almost the price of the blinds !! But thanks for you help.
Yeah, I agree, that controller is expensive…
The best is to use 120v motor and use the fibaro Roller Shutter 2 to control the motor. Around 60$ and works very good!
I put one for each of my 4 windows in my condo and I never had a problem.
For info on how to motorize shades with z-wave, contact:
info@zwavemotors.com
Thanks Zwave motor, I will for sure contact you.
In the meanwhile, PeterLuc, The friend group replied me that they cannot make the blinds I want with 120v motor.
I found another supplier perhaps who can give me 120V motor RF built in. Remote specs says 433.92Mhz. Research point me to that RFXUSB thing (Amazon.com)
Searching the forum on that I see plugin exist but that the use can vary a lot not specially blinds. Anyone wanna sharre their experience with that (I do not really need %, But I need to says Open so it goes up to the top and stop, down stop a the right closed position, and have a stop button to stop it let says in the middle)
[quote=“sturgeon86”]Thanks Zwave motor, I will for sure contact you.
Thanks[/quote]
I cannot guaranteed the operation with the 433 band and the plugin. I dont have that at home, but seem to work pretty well from feedback of other users.
In your situation, I would go with the other sellers with the RF control and then see if it would work to control it with the RF module. Much easier setup.
If it doesnt work, there is always other way to make it work with the remote and relay, etc.
I use http://rollertrol.com motors with the RFXtrx and the vera plugin. Works great.
