I’ve got a scene that runs every night. One light does not turn on when run by the schedule. The light status in the front end has no error. When I run it manually, it looks like it works.
I want to look at the logs to see what really happened. Where is the best place to see what is going on?
Start the following:
[url=http://YourVeraIP/cgi-bin/cmh/log.sh?Device=LuaUPnP]http://YourVeraIP/cgi-bin/cmh/log.sh?Device=LuaUPnP[/url]
Then use your Vera … activated the devices … scenes … etc that might be in question …
Save the above and look at it off line.
[quote=“RichardTSchaefer, post:2, topic:174468”]Start the following:
Save the above and look at it off line.[/quote]
Thanks for this. Somehow, I missed the fact that you could pull this file up through a URL.
You can save this to a file with a .html extension.
If you edit the file … at the top delete the following lines:
<script type="text/javascript">
function pageScroll() {
window.scrollBy(0,50);
scrolldelay = setTimeout('pageScroll()',100);
pageScroll();
</script>
You can then double click on this file to view it in the browser without the file automatically scrolling to the bottom.
Every Plugin/Device you install uses on average 2MB of ram.
If you do not use things (like the log file) regularly that is is wasteful.
If you only have a few devices/plugins … no problem!
