I recently added a new room (in Vera), moved my thermostat and scenes there and now the scenes are nowhere to be found. Th thermostat is right where it should be though. What’s up with this? Does it have something to do with the fact that the thermostat was set to “off” when I moved it?
@S-F
I tried to reproduce your issue, but I couldn’t. Can you please give me more details that might help me to reproduce it? For example what firmware version are you using? What type of thermostat and devices were linked to the scenes?
I don’t think loosing the scenes is because of thermostat state.
Please give me more details about the issue.
If you like, you may submit a trouble ticket and our support team will help you.
I’m running the latest FW, 1.1.1245 and 3.2. It’s a Trane thermostat. There were no other device involved in the scenes. One turned the temp down at 9 PM and the other turned it up at 5 and them up again at 6. It had been in my “kitchen” and I moved it to the “hall”. The kitchen has other scenes and devices but the hall only has the thermostat.
Is there anything else I can add that would be helpful?
Well, as if by magic the scenes reappeared in the dashboard. ![]()
