Where do I learn this stuff?
I’m trying to figure out how to set up some complex scenarios for when to activate scenes.
LUUP, is something I don’t know anything about.
I tried PLEG but it seems like I still need to know something about LUA.
I’ve tried following the instructions at RTS but I’m not sure what I’m doing. Every time I save something I get an error.
Can anyone point me in the direction of a tutorial for BEGINNERS who have no knowledge of how to use this stuff?
Thanks.
Learning LUA programming will give you the most power. But, it will take the most work and determination. You will literally have to become a LUA programmer.
LUUP Scenes and Event may give you enough to get you going. But, it will still be tricky. (LUUP extensions goes along with it.)
I suspect your best bet will be to troll the PLEG forum to see examples and go from there. A LOT of the work for all sorts of PLEG scenarios has already been done and posted here at the Micasaverde forums.
Start simple and build upon your successes.
Thanks, I didn’t know there was a PLEG forum here. I’m really glad I asked.
