Where can I find in UI5 the incredibly useful healing logs that were in UI4?
I tried looking at the UI5 logs, and while colored text is very nice, the results and healing attempts are not as nicely distilled.
What is it that you are trying to ask?
  • Garrett
The closest thing to what I’m looking for is the RepairReport file, located in the var directory on a Vera 3.
However, if I open that file using Windows Notepad, there don’t seem to be any carriage returns, so it’s hard to read (even though the words are plainly English). It’s a formatting issue: it reads like a giant run-on sentence. Is there a different program I should use to read it?
[quote=“garrettwp, post:2, topic:175929”]What is it that you are trying to ask?
  • Garrett[/quote]
In UI4, the repair reports were easy to open and read from within the UI4 interface. The reports were on a picklist on the z-wave repair page of the UI4 interface. A timestamped report was generated at the conclusion of each z-wave healing.
So, what I’m trying to ask is: can I read that same type of report from within UI5, and if so, where do I find it?
Issue resolved.
I found the files of interest in var\log\cmh.
If I open the files using the viewer built into WinSCP, they look perfectly well formatted.
