Can someone point me to the location if the D_ and I_ .xml files on the Vera3? I have a plug-in that I’ve uninstalled but the files persist and the startup Lua continues to try an run. I can still see all the associated files when I go to “Apps”, “Develop Apps”, “Luup Files” but there is no option to delete them, just view and download.
[quote=“swazi, post:3, topic:180460”]Is it safe to just delete these files if you know they are not being used anymore. E.g altsteon
Sent from my Nexus 4 using Tapatalk[/quote]
It is perfectly safe if you know they are not being used and the plugin has been uninstalled. If you delete a file from an App Store plugin that is still installed, it will download a replacement on the next restart.
