Greetings
All my logs show UTC timestamp. After doing the SSH found out that /etc/TZ file always remains null (zero bytes and nothing in it). Several scripts check the TZ file but I could not spend much time on it (having trouble with HSM100)
ntp updates the time back - any fixes/clues or is it a bad idea to change TZ
(BTW I am also missin the RTC /dev/rtc? )
root@HomeControl:/tmp/log/cmh# date -s 02042345
Thu Feb 4 23:45:00 UTC 2010
root@HomeControl:/tmp/log/cmh# ps -ef |grep -i ntp
7851 root 1312 S /usr/sbin/ntpclient -i 60 -s -l -D -p 123 -h 0.openwr
15120 root 2360 S grep -i ntp
Fri Feb 5 07:49:32 UTC 2010
Grrrr
regards
Keeper
PS: Case I could not find answer I will dig deeeeeper and will do the summary
