What The Latest Firmware Broke This Month... and ... What Still Isn't Fixed
1.7.1598
What’s NEW!
All Linear WD500Z-1 dimmable light switches show as ‘Uncategorized Device’.
I can change the sub-category from 3 to 0, but it only corrects the issue until I logout and log back in.
Thank you, Vera. ???
Different month, same old sh…tuff.
Errors from 13 weeks ago can be deleted. In fact they can be deleted over and over and over again because they always come back. Same logout/login sequence to activate this great long-term Vera feature. ::slight_smile:
This month should be 1.7.1625 (at least that’s what in beta now)… the version you’re running (1.7.1598) is dated from Nov 27, 2015.
I just pointed this out because you post made me go check my version to see if I was on the latest version or not.
I’m using Fibaro dimmers with no problems with 1.7.1598 (apart from some aditional devices that are created - and I simply ignore by putting then on a room just for that purpose :slight_smile:
[quote=“Qubit, post:1, topic:190642”]1.7.1598
What’s NEW!
Errors from 13 weeks ago can be deleted. In fact they can be deleted over and over and over again because they always come back. Same logout/login sequence to activate this great long-term Vera feature. ::)[/quote]
Are you the only one that the linear WD500z-1 doesn’t work on? I did a search for that model and none of the post were about the switch not working.
I hear you might like smart things. The grass is much greener on that side.
