I currently have a rainbird system that controls the zones and the relay to power the pump. Basically when it fires on a zone, it also powers the pump, then turns pump off when zones are done running…
I want to upgrade to one of these that would interface w/ Vera. I would like the ability to turn the pump ON/OFF through Vera so it shows up as a separate device along with separate devices for the zones. I also need at least 10 zones.
I think I need 2 ether rain controllers, and one of them being the model that triggers the pump switch I believe it was the model with “7P” in the name. can anyone confirm this is what I need and if I can see the pump switch AND individual valves as a child devices? thanks
Yes, you can create a device per zone if desired. However, I am not sure how it manages a pump zone as I do not have that model but logically it should be the same as other zones from a plugin, but that would need to be confirmed. Maybe contact their support for some conformation.
I have the EtherRain and now with UI5 and the Aeon Minimote, it can be easily controlled for each zone. I created a scene for the zones and allocated them to the Minimote. This way, I can turn them on without have to log on to the Vera. With the Minimote, you can it is a scene controller in UI5 see http://forum.micasaverde.com/index.php/topic,8630.0.html
[quote=“Brientim, post:5, topic:171773”]Yes, you can create a device per zone if desired. However, I am not sure how it manages a pump zone as I do not have that model but logically it should be the same as other zones from a plugin, but that would need to be confirmed. Maybe contact their support for some conformation.
I have the EtherRain and now with UI5 and the Aeon Minimote, it can be easily controlled for each zone. I created a scene for the zones and allocated them to the Minimote. This way, I can turn them on without have to log on to the Vera. With the Minimote, you can it is a scene controller in UI5 see http://forum.micasaverde.com/index.php/topic,8630.0.html[/quote]
Old topic I know, but is anyone able to comment on whether they had any success controlling a pump with EtheRain and Vera?
I’m in a similar situation and have an existing controller with pump start relay. I’ve looked at EtheRain previously but need to confirm ability to use / access the pump start relay autonomously with Vera - I.e pump is activated when a zone is turned on and vice versa.
Hello Fitzy,
If you use EtherRain-7P you don’t need to worry about controlling the pump relay terminal. On the EtherRain 7P the pump relay terminal automatically activates a few seconds before the cycle starts and stays on for the whole cycle.
This isn’t Z-wave based, but OpenSprinkler appears to be a very capable product. It is Arduino-based, networked, and appears to communicate well with other devices. I’m going to try it out if I ever get my sprinkler system in.
[quote=“ERdevman, post:8, topic:171773”]Hello Fitzy,
